endotherm
Flight distance : 503241 ft
RicardoGray Posted at 1-25 06:08
I agree with Nigel...……………….although I have never had to use that function. I have 2- Advanced aircraft and I checked both of them to see what happens when both sticks down and in. It does work, but there is a second or two delay, not an instant response. I do remember some time back, DJI seemed to be getting complaints of CSC commands being given by mistake by pilots and causing crashes. They then implemented that couple second delay to help avoid a mistaken CSC command. I'm thinking this was changed quite a few firmware versions ago...……..couple years maybe. I might be wrong about the time frame, but the command does still work on my phantoms.
Yes, it was introduced in response to complaints of CSC being accidentally performed in flight (although you'd be swinging madly on the sticks and flying irresponsibly if you did hit it...) so DJI introduced a full three second delay in firmware 1.10 and 1.11 (since November 2016). The three seconds is way too long in my opinion. It also has the unfortunate consequence of causing the aircraft to flip over if it is performed after you have safely landed -- instead of immediately killing the motors, it is receiving a command to pull backwards and descend and rotate and move sideways. This makes it stand up on one edge of the landing gear and tip an arm into the ground. It continues to do this for three seconds at which point it will turn off if you are lucky -- unless it has flipped to the more likely inverted position, where it will spin uncontrollably and ignore input from the controller. Not a very well thought out "improvement" by DJI to placate a group of fliers that were afraid of an extremely unlikely event occurring. This flipping behaviour was reported on the forum after the change was introduced, and was met by skepticism, me included. However, once I physically tested it for myself, I saw how dangerous it was. |
