DJI, plz fix Mavic's horrible camera focusing issues
8001 18 2017-1-18
ADIRU
Message to DJI, plz fix Mavic's horrible camera focusing issues
By default, all videos taken from the Mavic should strongly lean towards being more or less sharp by default for the vast majority of actual end user use cases as opposed to being by default almost entirely blurry and absolutely out of focus for each and every time a video is taken on a flight unless users actively remembers to intervene to help the Mavic set the correct focus. This is not only counterintuitive and DJI not only set 100% completely WRONG default settings/options/parameters etc but it runs against DJI's claim that the Mavic is its most simple and easy to use aerial photography drone, since even its Phantom series never had this "problem".
Also, in my opinion for a so-called "intelligent drone" that can take selfies, collision avoidance, active track this and redundant sensor that, etc it sure seems not so "intelligent" and "user friendly" or whatever one wishes to call it for DJI to essentially force the user to set the focus on each and every flight or else the video comes out all blurry. If its "deep learning" algorithm's can recognize a cat and a dog and a car and a human face, I expect it to be smart enough to take sharp videos without human intervention of having to manually set focus each and every time or else it DEFAULTS to blurry unwatchable videos EVERY SINGLE TIME. This is not normal. It is hard enough to worry about flying one shouldn't be forced to worry about a glitching camera focusing issue at the same time for each and every flight. It is so unusual that it caught many reporters and expert reviewers off guard when the Mavic first came out and they were reviewing the Mavic and they thought the camera was bad because all videos were blurry (by default) for them too. Yes, I get the photographic reasoning behind why or at least what motivated DJI to make this change as opposed or when compared to the settings in the predecessor Phantom drones for example, but it seems especially since the Mavic is targeted towards the more consumer/casual audience and touted by DJI as being a "convenient" drone ready at the moment to take off and snap pictures and take videos etc that this camera focusing "issue" of not being able to by default take sharp videos, is one of THE biggest dings for the Mavic that DJI should immediately fix in the next firmware update or in the next hardware version of Mavic 2. If DJI wants to set focus to something it should be the opposite default setting of sharp at distance, not blurry at distance, DJI set the completely wrong defaults that 99% of the use case for this drone/camera doesn't even apply for, it is completely illogical and makes no sense whatsoever. At the very least, DJI should give the end user a setting or option to manually override and set his or her own default settings. It is absolutely unacceptable to spend $1000 - $1500 on a drone and have it by default off the shelf out of the box take videos that are blurry and completely unwatchable. Especially for newcomers to this hobby or for people which whom the Mavic is their first drone experience, it is hard enough to master the flying aspect of it all without having to fiddle with the inconsistent and glitching camera/gimbal and now this huge focusing issue, then to finally upon successful flight attempt to watch the video only to find time and again that it was blurry and all the great recorders are unwatchable. Many user's first time flying experience with the DJI have been scarred and marred with bad memories of their first time videos coming out completely unwatchable after spending upwards of $1500 on a 4k camera getting worse than first generation flip phone camera videos, and its bad enough that the microprint font sized manual doesn't speak to this whatsoever nor warn the users of this critial design flaw that is completely counterintuitive. First impressions are important and for the vast majority of these newcomers, these first moments and first videos can never be brought back. The fact that DJI screwed this up so badly on a so-called smart drone is unacceptable and complete goes counter to philosophies such as Amazon's philosophy of "frustration free packaging" and whatnot. Whoever at DJI thought this was be a good change really hadn't thought it through or considered it from the actual end user perspective. Mavic being personally my first drone experience, I found the flight and flying aspect to this drone absolutely intuitive and a joy to fly, but the camera and video aspect to this drone absolutely horrible, counterintuitive, with the vast majority of my initial videos taken on the Mavic turning out to be completely useless and absolutely unwatchable. Given the stark juxaposition between experiences (day and night comparison really) between the flight experience with the Mavic and the camera experience with the Mavic, it seems DJI is really lacking in the camera/video experience, and a lot of it is due to the way they forced this new setting on users without setting it to a better default and without giving the end user any choice in the matter.
As an aside, I decided to buy the Litchi app instead of just using the default DJI Go app because for some reason DJI decided that waypoints must be preflown and also doesn't support more robust waypoint functionalities such as Litchi's and the other competitor of AutoLogic's Autopilot. Since I have an andriod phone and tablet and not an Apple person and Autopilot is only available on iOS at the moment, that means right now Litchi is the only real option for me. If DJI had supported more robust Waypointing and other things I surmise a lot of people wouldn't even need to upgrade to the Litchi app.
Camera focusing, whether automatic or manual, simply does not work for the Litchi app on the DJI Mavic at all. None of my videos taken with the Litchi app have come out correctly, despite my attempts to correct the issues, and all have been so blurry as to being completely unusable and unwatchable. While I have encountered problems with the DJI GO app in terms of setting camera focus, they have been corrected for the most part and I can now get videos with great sharp focus when using the DJI GO app, (albiet having to do a few extra steps each flight) however the same could not be said for the Litchi app on the Mavic.
Suffice it to say, I found the Litchi app buggy when it came to focusing the camera for video taking. Upon takeoff before using the Litchi's waypoint functionality to go on missions, I would often touch/tap to focus on an object in the distance to attempt to correctly set focus but everytime it would say something along the lines of "command timed out", and gave some wierd error message on the screen, and on the rare occasions that it finally took the focus command, it would momentarily get into focus, just to for no reason on its own seconds later get out of focus again. Being the Mavic has such a short battery life, and that the whole point of using Litchi's waypoints is for longer missions, I can't afford to waste five or ten minutes before each and every mission to fiddle around with the glitchy app focusing issues to get it just right, only to have it revert to blurry focus the moment it starts its waypoint missions. I also tried in the Litchi app to map "Center Focusing" to certain keys on the controller but although the mapping itself seemed to have worked, the actual focusing still doesn't get a good focus, and would lose focus immediately after getting a focus whenever it does get a focus. Effectively, all my videos taken with Litchi while flying waypoints have come back completely blurry and unwatchable, especially at night time, but also for day time videos/flights too. I have tried everything I could think of at this point and read the manual and help sections... So it is unusable for its intented purpose unless fixed by the developer support.
In my troubleshooting and as a hope of finding a means to get around this and solve the focusing issues, I attempted to set manual focus to the far distance in the DJI GO app and then hoping that it would carry over to the Litchi app. (in the past I found that many settings set in the DJI GO app such as battery warning level settings, etc carries over to the Litchi app so I was hoping for focus or locked manual focus that this might be the case too) I found that after setting focus to manual in the DJI GO app, in the Litchi app all focusing functionality stops working. If I were to touch/tap the screen, Litchi would completely refuse to even attempt to focus at all and in fact tells me that focusing has been disabled etc. However, when actually taking videos on flights I found that the Litchi app didn't actually abide by the manual focus settings that I had calibrated and set in the DJI GO app and it for unknown reasons used a completely different focus setting of its own, (while refusing to let me change focus since apparently once Manual focus is set in the DJI Go app the Litchi app completely stops letting users set focus at all) making this potential workaround absolutely unusable as well.
Last but not least, on waypoint missions when I had set POI's and then instructed the Litchi app to "focus" on certain POI's along certain waypoints, I imagined that in addition to calculating the pitch down angle of the gimbal based upon Waypoint distance/positioning and waypoint height, etc that it would also manually or automatically adjust the focus smartly as well in order to capture the POI at its sharpest possible settings, however through many test and trials, it seems this is not at all the case and there is no smart or intelligent camera focusing abilities or functionalities in the Litchi app.
For me, on waypoint mission flights my rc signal would often get lost at about 0.75 miles distance, much much less than the advertised 4.7 miles that DJI had promised, though to its credit, Litchi app seems to allow the Mavic to continue to rest of the mission unimpeded until it cames back within rc range again. The problem being, during the vast majority of these mission segments, since it is often out of rc range or suffers loss of rc signal, I wouldn't even be theoretically able to set /tap/touch to focus even if I wanted to, meaning the only way for me to keep these segments of these flights on focus is to either set a manual focus or to somehow lock the focus at a particular setting so that the camera cannot change focus again throughout the entire duration of the flight. However Litchi doesn't support and in fact has issues with all of these potential solutions. I don't see an option to hard lock a camera focus setting in the Litchi app, nor even an option to set manual focus in the same way that one can set a manual focus in the DJI app, and even when I set a manual focus in the DJI app it doesn't carry over to the Litchi app (as described above) and in fact makes it worse than before since it breaks focusing functionality in the Litchi app and Litchi won't even let me tap/touch to focus at all anymore.
Can any other Litchi Mavic users speak to these issues or am I doing something wrong or missing something that is easily solvable?
Why is there not an option or setting in the Litchi app to set a hard lock focus setting so that focus is locked at that setting for the entire duration of the flight? This would seem to solve the horrible automatic focus (unusable) issues that I'm having with the autofocus in the Mavic with the Litchi app, and also for long waypoint missions where rc signal is lost, having the ability to manually pre-set a focus setting and have the app hard lock it for the entire duration of the mission would come in extremely handy as an option of last resort.
2017-1-18
StigNygaard
Flight distance : 357169 ft
Denmark
Sorry, I didn't read your full post. It is a bit long. But from the first parts if it, I just need to mention a few things...
In principle the (tap-to-)autofocus is a step up compared to the earlier Phantom 3/4 models and to action cameras like GoPro. Cameras in the the earlier DJI Phantom models (and most action cameras)  are fixed-focus cameras where focus cannot be changed. It is fixed to one setting, relying on depth-of-field to make things in typical distance (for most use) reasonably sharp. The Mavic is actually a step more advanced making it possible to get focus on things closer to the camera/drone than most other consumer models allow.
DJI could maybe have made a default distance-setting(*) in the camera which would give a similar effect as the fixed distance on Phantom 3/4, and maybe they should have done that seeing how many people is finding it difficult to remember to focus before filming. But if you are an advanced user, you would see it as an advantage to have autofocus like in the Mavic.
With the DJI Go 4 app, DJI has implemented a kind of semi-contentious autofocus mode. Exactly how it works seems to vary from user to user. But the idea seems to be to periodically re-focus. This can be good for some, but if you are just a little ambitious with your filming, you definetely don't want to re-focus in the middle of a recording, because the way the autofocus works it has to make the focus a bit unsharp first every time it re-focuses, to see how the distance should be set to have optimal focus/sharpness.
(*) You can "mimic" the DJI 3/4 setting by focusing on something a few meters in front of you after take-off, everything from a little closer than this distance to infinitive should be sharp. Only if you focus on something very close you will see things in the distance get unsharp.
2017-1-18
R&L Aerial
Flight distance : 298100 ft
I like my mavic???
2017-1-18
hallmark007
Flight distance : 9827923 ft
That's too long winded I'm with Aerial , I like mine, it's everything I paid for...
2017-1-18
DJI-Ken
Flight distance : 1515312 ft
If you can make bullet points of what the camera is not doing.
If you enable Manual Focus and then set the box in live view to MF, then it will not auto focus.
2017-1-18
Airwolf13
Flight distance : 36995 ft
Drive on dude. You are spot on, long winded but totally correct in your assessment. DJI. Are you listening???
2017-1-18
Freaze
TLDR. op please sum it up for us that have ADD
2017-1-18
fans15a2e56a
Flight distance : 153268 ft
I love the Mavic but he is right , the thing should default to far away focus and we should tap to focus for things up close . That way I would get more usable video when I forget . After years of flying with cameras that did not need that attention , it's easy to forget to focus
2017-1-21
bochen7
This issue still not been fixed on the latest firmware update.....
http://forum.dji.com/thread-85204-1-1.html
2017-2-15
Wildersachse 4
Switzerland
The issue has been fixed!
Go to the camera settings, where you typically change the video size, histogram, grid and so on, there is an option to disable the continuous autofocus!
2017-2-15
bochen7
Wildersachse 4 Posted at 2017-2-15 16:36
can someone confirm this is true?
(i haven't updated yet)
2017-2-15
alirz5
Flight distance : 609833 ft
It's not a fix, it's an option to disable auto focus.
2017-2-15
Yusef
Flight distance : 12146 ft
Um K.  No need for an essay bro...2100 word essay?
2017-2-15
mobbit6
Got the mavic  a week ago, the first couple flight the video was ok, now the focus is kinda soft and blurry, it seems that the camera auto focus doesn't work 100% all the time.
2017-3-4
fans66b40091
Flight distance : 379180 ft
Greece
Unfortunately, mavic's camera is a disaster. Its impossible to get  a nice video. Is blurry and out of focus. Also its impossible to  get a nice photo  in low light conditions. I'm really disappointed from this camera...
2017-3-22
PimpDawg
Flight distance : 1204754 ft
fans66b40091 Posted at 2017-3-22 14:08
In low light/night time try putting the camera settings on manual - 1600 ISO and 1/60 shutter. It works well for me.
2017-3-22
cristianc
Flight distance : 1008143 ft
PimpDawg Posted at 2017-3-22 14:15
That I agree, Mavic doesn't handle low light very well hence this is where is the manual settings comes in place.
2017-3-23
Salish Sea
cristianc Posted at 2017-3-23 06:00
Few cameras with sensors as tiny as this will be good in low light.  That's why full frame cameras shoot the best in low light conditions.  The bigger the sensor the more light it can catch.  My Mavic has been pretty nice so far ( A week or so) but I did notice a little softness when it was looking at a POI running Litchi on one mission.  I'm pretty sure it had to do with that.  More testing!
2017-6-20
RCNJ
Flight distance : 114665 ft
mavic - small enough to take anywhere (but give yourself 9hrs trying to get the focus and settings all correct to record your favourite moments!) i'm new to this but I have to agree with some parts that as a take off and use expensive drone the video side of things is not impressive (without being a visual professional knowing what everything should be) as a "general" user and not a photography expert it seems it is really for people who want to post edit, grade and get it all nice, the ones who bought it as fun to fly and record great looking video end up with poor videos & then spend more on tools trying to make them look better.
Ive tried various settings, been all over youtube setting vids, bought ND filters, tried on/off ND's and shooting at 4K 30, 2.7K and i still struggle to get anything with a wow factor....
actually a friend of mind wanted to get one, he could not wait, one evening watching clips and he has decided not to! DJI needs to get this recording in a place where its great for beginners and awesome for experts.
its great to fly, stable and has good features, but general default video needs to be better as it seems everyone has different views, if i pull my iphone out and record I know its going to be good, if I hit record and spend 20 mins flying only to find it looked great on app but not so good on the vid files its just gets you down a bit.....come on lets have some update to cure this before i swap it for something else
2017-6-20
