A3 Assistent 2 update 2017-1-18
2997 17 2017-1-18
ducpeter
Flight distance : 62175 ft
new firmware for A3
http://www.dji.com/a3/info#downloads
I installed today the new A3 firmware 1.7.0.0 and new assistant 1.0.9-2 without any problems
my S900/1200 with A3/LB2/ Z15GH4 everything is working including intelli-g
also on my S900/1200 A3/LB2/X3/5 no problems incl. 1 and 2 pilot solution
waiting for the LB2 update
2017-1-18
SkySight Aerial
Flight distance : 3312018 ft
Me too, eight months and counting...................
2017-1-18
SpecialCshoe
Flight distance : 397139 ft
I just updated to firmware 1.7.0 and I get a loading symbol when loading Assistant 2 1.09.
2017-1-18
ducpeter
you need the new DJI assistant 1.0.9-2 on the same page on the left side after upgrading
2017-1-18
SpecialCshoe
Oh geez! Thank you so much!  Now it works beautifully
2017-1-19
ducpeter
it flys very smooth but to slow max speed is 49/50 km/h
please make it customised in the assistant
2017-1-21
DougyBear
Flight distance : 1718419 ft
Hi just read your post we have a intelli-g on a Vulcan Black Widow with A3 Pro/LB2/Z15GH4 we also installed the new firmware and she flys like a dream but we still can get the LB2 to see the intelli-g do you have a idea. Thanks
2017-1-24
HELOUAV
I did the firmware update to 1.0.9-2 and am still getting and error of aircraft needs firmware update and a battery authetication failure.  any solution to this?  I am still waiting for support to reposnd to my case,
2017-1-24
DJI-Jamie
Flight distance : 112405 ft
HELOUAV Posted at 2017-1-24 17:07
Have you tried restoring to factory settings and redo your parameters? Have you tried reinstalling the Assistant 2?
2017-1-24
HELOUAV
DJI-Jamie Posted at 2017-1-24 23:46
I have reinstalled 3 times and still getting same errors. How do I go back to factory settings?  does not give me a downgrade option. Iam not much of a tech head so this is a bit of a struggle.
2017-1-25
DJI-Jamie
HELOUAV Posted at 2017-1-25 16:09
On the Dashboard, you will see a 'restore' button, that will wipe the unit of presets, but it will not affect the firmware. Just to clarify, you don't see previous firmware listed below the current one when you are in the firmware section?
2017-1-25
HELOUAV
DJI-Jamie Posted at 2017-1-25 20:14
yes that is correct., Please clarify dashboard as I am not sure I am seeing what you are describing
2017-1-31
HELOUAV
I have Asst. 2 version 1.0.9-2 loaded and tried to upgrade the firmware. Says version 1.0.0.80 as current. getting firmware upgrade required and battery authentication failed
2017-1-31
DJI-Jamie
HELOUAV Posted at 2017-1-31 14:38
The Dashboard with the Restore button is as follows:
2017-1-31
DJI-Jamie
HELOUAV Posted at 2017-1-31 14:40
That's odd, you are using an A3 and not a M600, correct?
2017-1-31
HELOUAV
DJI-Jamie Posted at 2017-1-31 15:50
m600 pro with A3 pro flight controller
2017-1-31
HELOUAV
DJI-Jamie Posted at 2017-1-31 15:49
[view_image]
Jamie,
I don't have the dashboard option on my Asst. 2. Everything else except. will try to snag a screen shot for you
2017-2-1
Kover
Belgium
HELOUAV Posted at 2017-2-1 04:32
Jamie,
Maybe a bit late and I hope your problem is solved by now but I didn't get the dashboard neither. Then I tried all the different USB-cables I had on all the different USB-ports on my laptop until finally one did the job and the dashboard appeared. So it could be as simple as that. Also DO NOT use any USB - micro-USB adaptor, that caused a lot of headache as well...
Cheers
2017-5-16
