Dronoob
Flight distance : 126079 ft
stratosHD Posted at 2017-1-19 19:43
I would appreciate as well if the hub could charge all batteries at the same time. But for me does the job.
Still, Ive seen that there are a couple of aftermarket chargers that can charge all at the same time.
What does the charger do? Well, it pushes a particular amount of electrical power into the batteries. The amount of power that it put into the batteries is limited by the charger itself. A 50W charger gets 50W into the batteries. A 100W charger gets 100W into the batteries.
The DJI charger is able to charge one battery in about one hour. To do so, it has to deliver the max power it can deliver. But this means, if you charge two batteries at the same time, the charger power is split between the batteries and both of them only get half the power. If you charge four batteries, they only get a quarter of the power.
In the end, charging batteries simultaneously will require a longer time to fully charge the batteries. Charging them one by one will give you one fully charged battery much earlier. This is also the reason why the fullest battery is charged first. |
