Barometric measurement consistently reading negative ground level
611 4 2017-1-18
Wind Junkie
Flight distance : 116165 ft
Hello
I've noticed that when vision system is not reading height from the ground, the height consistently reads negative. My picture below is what I took of my Mavic idling in place on the floor in my house. The reading slowly works its way down to negative 2 - negative 4 feet without moving, just idling in place. If I'm outside and I go fly around, when I return to eye level height, the distance reading is again usually negative. Sometimes reading negative 20 feet. I always do a compass calibration before the flight, though I don't think that should matter in this instance. Any ideas why I am constantly reading a negative height? Anything I can do to fix this? It seems specific to the barometric reading since DVS usually is able to properly identify the height.
Thanks
2017-1-18
Hello Wind Junkie, please try to do the IMU calibration on a complete flat surface.
Let me know if this helps.
2017-1-18
Wind Junkie
Hey Mindy I'll try and update once I re calibrate. Thank you
2017-1-19
Griffith
Flight distance : 98537 ft
When you activate the props, do you leave  the Mavik on the ground (floor) for a while,  or ascend a few feet?
I don't have any knowledge of the barometric sensor location or when, in the initiation process, the reference pressure is taken - immediately upon power-on, immediately upon prop activation, or a few seconds later.  However, I can conceive of a situation where the drone, on a flat surface with props whirling, could create a higher pressure zone around the lower body of the drone during the baseline pressure reference measurement, thus leading to a negative (relative) pressure reading while hovering.
Just thinking out loud :-)  Maybe the DJI software folks could shed some light on the initiation process.
Try ascending a few feet immediately upon prop activation.
2017-1-19
fans8296c24f
Griffith Posted at 2017-1-19 08:14
Good post even though I have not experienced this, I would love to know what the resolution is for this problem.
2017-1-19
