kykphantom
Flight distance : 5892388 ft
Cyprus
Alexdroner Posted at 2017-1-22 01:30
The noise sound like the internal fan causing the case vibration, loosen the screw with Allen key and tighten it again should fixed it, indeed the fan might be a better airflow design but a higher vibration design as well. You can try the live feed or slightly touch the camera to see if it is vibrating. Trust me even through some parts are bad designed, but with some little fix, it will be prefect. I can take 4s long exposure in almost all conditions. The gimbal lock can be deform using hair dryer and the p4 absorber set can be bought from eBay, I will guide you thought the replacement process.
Alexdroner, thank you very much, You are really very good man, trying to help, I appreciate it. DJI should have such people in their support, they would have had much better support service! |
