Ambient Light Too Low For Avoidance Sensors
15052 8 2017-1-19
phinchman
Flight distance : 120994 ft
Puerto Rico
Hello, All:
I have a brand new P4P, have flown it only a couple of times.  Last time I flew, I kept getting alerts in DJI Go 4 that the ambient light for my avoidance sensors was too low.  Granted, it was a cloudy afternoon, but I'm wondering:
1.  Is there an ambient light threshold guideline that needs to be met?
2.  And for future reference, do the sensors need cleaning from time-to-time to avoid such occurence/alerts?
Thanks, in advance!
2017-1-19
Maxi3D
Flight distance : 307621 ft
In the manual, it says the light have to be greater than 300 lux for it to work.
2017-1-19
phinchman
Puerto Rico
Thanks, Maxi.  The "lux factor" where I was was definitely greater than 300.
2017-1-19
SureshR
Flight distance : 354 ft
phinchman Posted at 2017-1-19 12:02
Will having those lights on the drone help this situation? I saw some lights which can be attached to the landing legs. Will they help in avoidance detection during nights?
2017-1-19
Quadcopter Land
SureshR Posted at 2017-1-19 13:37
Obstacle avoidance even with lights does not work at night
2017-1-19
Quadcopter Land
If you installed the lastest firmware, you will loose some sensitivity on front and rear sensors.
2017-1-19
fans8905bd1d
Flight distance : 2602559 ft
Norway
Have You remove cover ( transparent plastick ) from sensors.
2017-1-23
ProQuad
Flight distance : 20296870 ft
1.   Yes, please read the manual.  300lux I believe
2. Yes. The sensors need to be cleaned if dirty.  Check before each flight
2017-1-23
RedHotPoker
Flight distance : 165105 ft
Are you referring to Lume Cubes?
http://www.lumecube.com/164.html
Yes, they would help enable OA, if you were flying close enough to the obstacles.
RedHotPoker
2017-1-23
