Punchbuggy
Flight distance : 483166 ft
Not bad, but after reading about new directions in tech being pursued, I suspect the P5 is likely to utilise Warp Transition Factor technology - or WTF for short. That way it can land before it takes off. Further, height and speed limitations may be removed, and the P5 instead restricted to 4 dimensions only.
The new P5 will likely be accompanied by a new RC unit to suit the craft's new capabilities. Whereas the old version relied heavily on Lightwave transmission technology, this new RC will instead need to utilise the new Lightyear transmission tech, effectively allowing the P5 to be guided to the far side of the Universe.
I suspect the only caveat with such flying will be to be wary of degraded planet avoidance sensor performance, because if the sensors are facing Black Holes their performance may be affected. |
