Switching between iPhone and iPad - seamless?
1436 3 2017-1-19
SpeedVision
Flight distance : 516168 ft
Does the Mavic store the settings from the DJI go app? Reason I'm asking is I would like to use multiple Apple devices as the monitor based on different situations… If the Mavic stores settings then I should be able to do this seamlessly. If the settings reside in the Go app then it will likely be difficult to have identical set ups on both devices…
If you have experience using multiple devices, please chime in and share your experience. Thanks!
2017-1-19
Hummingbird.UAV
Flight distance : 27489951 ft
My experience with DJI drones is that the setting are saved in the drone.  Some are not.  Camera settings, RTH settings, control exp are saved.  GEO does not.  Settings do transfer between apps as I have used Go 3 and Go 4 and settings have transfered.  However it is recommended and very easy to check the settings when switching view devices.
2017-1-19
SpeedVision
Hummingbird.UAV Posted at 2017-1-19 16:26
Thanks for the info!
2017-1-20
djiuser_JDXwnSvsgTxH
Flight distance : 1565 ft
Is there a step by step way to switch between iPad 11 pro, and iPhone 11 Pro? Have mini 2
2021-4-19
