GB44
Flight distance : 343848 ft
fdnyfish Posted at 2015-10-25 07:09
I have 2 Sandisk 64GB Extreme Pro cards that worked fine in my Phantom 3, but will not work in my Inspire 1. I was told in another forum that there is an issue with 64gb cards with the inspire. When I used the 64 gb cards, after 4 minutes of flying, I noticed the slider was switching back and forth from video to photo on the app. The inspire 1 was unable to format the card. Formatted both cards in PC fine, then put into Inspire and it formatted the cards, but same would happen after about 4 minutes again.
So I tried the 16gb card that came with the inspire and al is well.
The most I have used is a 32GB Sandisk. The 16GB cards are generally big enough for flight times and you can swap them out after each flight if necessary. I tend to just use a 32GB for about three flights and never have any problems. Obviously after downloading images etc. I delete the card ready for next time.
