Battery firmware update question
851 4 2017-1-21
HWKIDD
Flight distance : 22877 ft
I received a new battery today,   and  charged it up and put it in the Mav, to check it out tonight,  Expecting it to
give me a message,  that the battery would need a update,   like I had on my number two battery when I put it
in after I did the last update,   But  No...  does this seem right?   Anyone now for sure?  Thanks in advance
2017-1-21
BradC234
Flight distance : 219770 ft
Maybe the update was already done from the factory? That's the only solution I could imagine, if the firmware was inconsistent than I'm sure it would notify you.
2017-1-21
RichJ53
Flight distance : 1837356 ft
Most likely the battery was updated already in production. You can connect your Mavic using DJI flight assistant 2 software / on the PC /  with the new battery inserted. If this new battery needs an update, it will tell you for sure.
Rich
2017-1-21
HWKIDD
RichJ53 Posted at 2017-1-21 21:34
Rich
thanks will try that
2017-1-21
If there's no update available then you don't need to worry about it.
2017-1-22
