Videos writing date as 1951?
1010 13 2017-1-22
kingstonphoto
Flight distance : 160197 ft
so weird but only my video files are writing with a year of 1951 the rest of the date is correct. but the year is always logging 1951?
2017-1-22
Cabansail
Flight distance : 136686 ft
"It's just a jump to the left.
And then a step to the right.
Put your hands on your hips.
You bring your knees in tight.
But it's the pelvic thrust
That really drives you insane."
2017-1-22
Punchbuggy
Flight distance : 395551 ft
It's a known issue, and there are already threads on this. Here's one: http://forum.dji.com/forum.php?m ... D386%26typeid%3D386
2017-1-22
Todka
Flight distance : 452267 ft
On the bright side, at least it incremented after last year's 1950 time stamps.
2017-1-23
DJI Natalia
Super Moderator
Flight distance : 318 ft
May I know what SD card you're using ? Do you have the same case if using the original SD card coming together with aircraft?
Also please try to upgrade the firmware to the latest and check again, thanks.
2017-1-23
kingstonphoto
DJI Natalia Posted at 2017-1-23 04:18
im using a sandisk extreme card. I don't have the card that came with it anymore.
2017-1-23
DJI Natalia
Super Moderator
kingstonphoto Posted at 2017-1-23 15:56
You have upgraded aircraft firmware to the latest or not?
2017-1-24
kingstonphoto
DJI Natalia Posted at 2017-1-24 02:55
yeah its upgraded. ALSO  I found the original SD card and it does the same thing.
2017-1-24
DJI Natalia
Super Moderator
kingstonphoto Posted at 2017-1-24 09:40
Once the file is moved from SD to other media, the created file will be changed at that moment. Please show us this detail which may help to locate the issue.
2017-1-25
Bulldog50
Flight distance : 38825 ft
Same here. Firmware is up to date. Lightroom seemed to change the date to 1950/1951
2017-2-3
kingstonphoto
ive tried everything its still writing them on import as 1951... any solutions on this?
2017-2-15
kingstonphoto
still no fix? I notice its only on videos
2017-3-3
Geebax
kingstonphoto Posted at 2017-3-3 13:34
Maybe ask on an Adobe forum?
2017-3-3
kingstonphoto
Geebax Posted at 2017-3-3 13:54
doesn't happen to any other card only phantom 4 pro
2017-3-3
