It's been awhile, Z3 is do for an update!?
688 8 2017-1-23
BIGDZ
Flight distance : 10255860 ft
okay, I ve been flying my I1 Z3 for a month or so, and been ignoring the update, well... I can't update the new I1 fw because my Z3 won't let me(don't have x3 or x5). So when will there be an update for the Z3. I have the MOST RECENT fw to date...really curious....
2017-1-23
Mark Guille
Flight distance : 2031818 ft
Jersey
What F/W are you on presently? It may be that you are not missing anything and therefore no point in updating. DJI are aware of the issue so fix is imminent.
Hold tight there dude, I'm sure it's on its way.
Mark G.
2017-1-26
BIGDZ
Mark Guille Posted at 2017-1-26 02:07
I'm on the most recent fw(believe that's 1.9.1.4) . Hard to be patient when (z3) owners have been dealing with issues since it's release, so I think I( and other owners) have the  right to  be impatien,t as well as upset; drop $900 on something that doesn't work as promised, and see how you feel!
2017-1-26
Mark Guille
Jersey
You didn't mention you were having problems with your Z3. What is it doing, or not doing?
2017-1-26
Yellowstone Dro
I have only a Z3 as well with my Inspire 1 the latest update is V 1.9.1.40 and if you run it it updates the camera but not the aircraft which is left at V1.9.1.30 and the app indicates the aircraft needs upgrade.
Haven't been able to workaround this problem. Im with BIGDZ,For $900 this thing should work perfect out of the box or we should be refunded our money. DJI support has no idea what to do.
2017-1-26
DJI-Jamie
Flight distance : 112405 ft
BIGDZ Posted at 2017-1-26 04:38
What issues are you currently having with the Z3? The last time I followed with your rig, the 4K latency for FPV could be improved but otherwise functioned well. Is there something I've missed thus far?
2017-1-26
DJI-Jamie
Yellowstone Dro Posted at 2017-1-26 08:04
I had brought this to the Development team to provide the v01.10.01.40 when updating with the Z3. It was something being worked on. This aircraft firmware only removed a few NFZ areas, but no other aircraft improvements were mentioned. If your unit is working well, you can skip this firmware for the time being. If you happen to have a local dealer or a friend who has either an X3 or X5, you can update the aircraft that way.
2017-1-26
BIGDZ
DJI-Jamie Posted at 2017-1-26 15:56
No issues (yet) all seems to be working, just wondering if there will be a solution for upgrading new/future fw updates.
I understand this FW update  isn't a big one, but what happens when the next one comes and you guys still have no answer. I honestly don't have a place to go to;  to borrow an x3 to update new fw releases.
2017-1-26
DJI-Jamie
BIGDZ Posted at 2017-1-26 19:38
I'm looking into getting that addressed. Worse case if there's a bigger firmware coming out sooner than the need for the v01.10.01.40, then we will ensure that a Z3 update package is made available.
2017-1-27
