Micro SD card
1159 6 2017-1-23
ProQuad
Flight distance : 20296870 ft
When I purchased my Mavic it came with a Lexar 633x 16GB HC I micro SD card.  I was thinking of replaceing it with a Lexar 1800x 32GB (or 16GB which ever will work the best) HC II micro SD card.
Looking for any feedback from anyone especely DJI.  Thanks.
Front
Front
Back
Back
2017-1-23
fanscbe312e7
Flight distance : 306722 ft
My feeling is you will spend 3 times the amount and you will not notice the performance at all. The speed of the card that comes with it can support all the recording needs of the Mavic camera. Hope that helps.
2017-1-23
dana5
Flight distance : 14354 ft
Yawn... This topic has been covered SO many times... Do a search, and you will find about 15 threads on this topic, that all say the same thing.
2017-1-23
fans6394d9c6
Flight distance : 69787 ft
Any card that is rated UHS-I  will work.   I personally like the Sandisk Extreme 32GB are like $15  the 64Gb are $30.
Make sure you get a USB 3.0 chip reader.  Many people don't get a good reader and then think its the fault of the chip.   Also plug in the chip reader to a 3.0 USB port (the blue one)   or USB-C is better if you got it.
4K video files ARE BIG - too big for many laptops to deal with without pain.
2017-1-23
ProQuad
fanscbe312e7 Posted at 2017-1-23 11:30
Thank you.
2017-1-23
ProQuad
dana5 Posted at 2017-1-23 12:02
Right, you are SO right.  I did do a search, did find threads, but it is SO argumentative and back and fourth that it really does not make any sense as too which one to use.  Thanks for your reply.
2017-1-23
ProQuad
fans6394d9c6 Posted at 2017-1-23 13:11
Agreed.  USB 3.0
Also, just looked at it and it says UHS-II on it.  I can assume that the II is better then then I??
2017-1-23
