Cetacean
Flight distance : 2528264 ft
Aloha Leonardo,
Since you already have a project planned, your best option is to try to duplicate the flight as much as possible. This way, you will be able to operate the Phantom with more confidence. Reading the manual more than once is also a good confidence builder. The manual will give you a good overview of setting needs.
In the General Settings (upper right of "Camera View" screen, 3 short lines) are the flight settings and options. The most important will be "Gimbal". Be sure the gimbal setting is for "Follow", not "FPV". Follow will be blue, but test the touch process of choosing settings by changing the setting between Follow and FPV back and forth. You will see that after you set the gimbal on Follow, the setting turns blue. FPV requires a lot of work to get it right.
To help you, I have attached three images that will help you understand better how to use your Aerial Camera and what settings to use. Read them over until you have a better understanding of how to make everything work the way you want it to.
Aloha and Drone On! |
