Litchi Video Downlink Signal Indicator
954 1 2017-1-25
WindBlade
Flight distance : 1949 ft
Hi all, I'm using Litchi with a P3S (stock) and a Samsung Galaxy Note 3 (DJI Go not installed).  I'm flying short distances ( < 500 ft) in open areas like parks and the drone is functioning properly. I'm even getting good video feed on my screen. The issue is the video signal strength indicator on the screen in Litch. I keep getting zero bars! Nothing is blocking the front section on the RC where the downlink receiver is. I'm getting no red disconnect messages and the telemetry signal strength indicator is maxed out with 4 or 5 bars. There is only the slightest bit of lag in the video, which I assume is normal. Anyone have any ideas what the issue may be?
2017-1-25
djiuser_oPre39Z
Did you ever get this sorted? I have the same issue with my Mavic Pro. all works correctly, but video-downlink bars show zero signal.
2017-7-31
