Phantomski
Flight distance : 14869882 ft
beginner mode, or distance limit? I have seen quite a few of these lately....
Side note, you did not let the battery warm up, and missed the warning about battery being below 25C temp, next time hover around until that is ok.
As far as the log goes, i see the RTH altitude set, but I never see actual Home point recorded (usually happens when u start your motors), you did not wait for the GPS to be ready, you took off in ATTI mode, before GPS was linked.... that is always risky, as Home is unknown.
That is my guess.. Now, why would home not be recorded as soon as GPS becomes available, I am not sure.. but i cannot find where it defines what home is.. perhaps that's the issue.
Definitely contact DJI support.
Did you read the manual well and did any tutorials before flying? This is a complex aircraft, and really needs to be understood before use. Way too many things that can go wrong if one does not really understand how things work.
Good luck!
