Return Home only goes higher
834 7 2017-1-27
StefanoRem
Flight distance : 323225 ft
Luxembourg
Hi!
Recently buyed a P4 Pro Plus. It works very fine!! No errors, nothing! Return home always worked very fine, but now, since the last update ( i think ), when i click RTH, it only goes up, it only goes higher. It goes very high like 140 meters so i always cancel RTH because i don't want it to get that high. My settings are correct, the RTH Altitude is 30m, so that's not the problem.
The drone just only goes higher, and it doesn't move vertically.....
Anyone who knows how to fix this? Do I need to reset the settings?
Thanks a lot,
Stefano Rem
2017-1-27
Labroides
Flight distance : 9991457 ft
Update to the latest firmware which corrected this.
2017-1-27
StefanoRem
Luxembourg
But the DJI GO app says I am on the latest firmware?
2017-1-27
StefanoRem
Luxembourg
And of course i mean, ''it doesn't move HORIZONTALLY'' instead of vertically ;)
2017-1-27
StefanoRem
Luxembourg
Just tried again, checked if the drone needed a firmware update, but it says it is on the latest firmware. Is there any other way how I can fix this because my RTH does not work now :/
2017-1-27
StefanoRem
Belgium
Labroides Posted at 2017-1-27 05:36
still no updates.... do you know what i can do now?
2017-1-29
Labroides
StefanoRem Posted at 2017-1-27 09:06
RTH does not work?  More details please.
What is it doing?
What firmware is your Phantom showing?
You can check this in the app.
Go to settings and click the 3 dots icon down the bottom.
Go to the bottom of that page and click About
2017-1-29
StefanoRem
Belgium
Labroides Posted at 2017-1-29 06:01
What is it doing?
Yes. So when i click return home, the app says RTH is activated and like that, but it's only going higher. My height setting for RTH is 40 meters, but it goes much higher than that. I always cancel RTH early because otherwise it takes too long for getting down.
My firmware version is 01.02.0304
The app version is 4.0.0
2017-1-29
