solentlife
Flight distance : 1087530 ft
Latvia
Why not just increase the Expo in the Go app to reduce the deflection control amount around centre ?
Expo is used to soften the command around centre ... making you move the stick more to get same control response as previous. It also helps reduce interaction of commands. It is common for a person to want to move stick just forward or backward ... but a small amount of side gets in as well. Expo reduces that as well.
With conventional fixed wing - as the model gets faster or more aerobatic - its common to increase Expo to high levels to stop over control at small stick movements. But still give you full when you want it.
The above additions to sticks are great idea - I agree - but could not be done on many RC as the tablet / phone would be in the way when pushing forward on sticks. I already have to set my tablet up a bit at the bottom end to allow my thumb and stick to pass under.
Your additions are to a stock RC ... once you modify to larger tablet etc. - you will see what I mean.
Nigel |
