High capacity battery hard to remove
630 12 2017-1-29
early
Flight distance : 15358 ft
Hello,   I have one battery that is really hard to remove,  takes both hands & I'm worried I will damage something.  The release will not depress enough to clear the catch.  I have to work it back & forth and sometimes use a pocket knife to push the locking tab before it will let go.   Is anyone else having this type of problem?  I have 3 batteries, 2 of the original P4 & 1 of the high capacity.  It is the high capacity battery that is hard to remove.
thanks!  I hope this makes sense?
2017-1-29
Mark The Droner
Flight distance : 2917 ft
Are you sure you're removing it correctly?
2017-1-29
early
Mark The Droner Posted at 2017-1-29 05:42
Thanks for the reply, Yes, I believe so, I  remove the other 2 batteries with no problem, only the high capacity  sticks every time.
2017-1-29
Mark The Droner
A drop of salad oil might help.
2017-1-29
Punchbuggy
Flight distance : 483166 ft
It's all in this thread.
http://forum.dji.com/forum.php?m ... D386%26typeid%3D386
The technique shown in the video surprisingly works...
2017-1-29
RedHotPoker
Flight distance : 165105 ft
You might have to squeeze it a bit firmer, than the others. This has been explained.
It should loosen up a little, with more use. ;-)
RedHotPoker
2017-1-29
early
RedHotPoker Posted at 2017-1-29 13:37
lol, I am giving it all I got,  I am hoping it gets better.   I did a search, wasn't much help.
thanks for your info & help,.
2017-1-29
early
Mark The Droner Posted at 2017-1-29 07:18
I might try try that,  thanks
2017-1-29
early
Punchbuggy Posted at 2017-1-29 13:21
Lots of information,  thank you!
2017-1-29
RedHotPoker
early Posted at 2017-1-29 13:52
You need to build up the hand muscles, not have a loose flight pack. Haha
But yeah, I know what you mean. Having a battery that won't budge, can try ones last raw nerve...  ;-)
RedHotPoker
2017-1-29
PhantomPhil
Flight distance : 44731 ft
Yeah, I know what you mean. Just need to get a grip :-)
...some folks complain about it being too loose, I prefer I tight fit.
...and the salad oil. Hadn't thought of that one!
2017-1-29
Punchbuggy
RedHotPoker Posted at 2017-1-29 14:06
Well, that video in the other thread has the technique. I was very sus it would make a difference removing a stubborn battery, but it just slide out that way. Put it back in and tried with one hand, and the bugger just woudn't release. Used the technique again, and it just slide out as before. Amazing.
2017-1-29
RedHotPoker
Punchbuggy Posted at 2017-1-29 14:38
That's something the manuals would never have explained. So we all, are fortunate to have the wisdom of the forum regulars and mods here. ;-)
Glad it has worked for you, & so did you feel the weight, lift off of your shoulders, when it released the battery... Ha
And exhale... ;-)
RedHotPoker
2017-1-29
