solentlife
Flight distance : 1087530 ft
Latvia
Charging from PC is worst option you can take ...
Just get a bog standard phone charger with the micro Samsung style usb plug and charge with that.
As to amp rating .. anything 1A or more up to 2A ... the RC itself will regulate the rate it charges - not the charger.
I have one of those dual output car USB outlets as well ... so I can just take a cable and plug in RC to car if needed.
OK as to time to charge : The RC has a large capacity low voltage LiPo battery ... 2600mAh 3.7V .... based on the RC regulator - this can take up to 3hours to charge if you have it well down.
The battery is reckoned to be good for 15 - 20 good flights per charge.
One thing to remember : Do not drain this battery down to near zero or below 10% ... its a LiPo and it will not appreciate the damage caused. Being a low current draw item it powers - there is actually no real harm to just top up charge this every so often or before going for a flight session. Unlike a high power draw item such as the AC - top up of RC is not a problem.
Nigel
