Anyone else notice that when you use a filter on the camera that the camera is not as stabile. I always seem to have issues when I use a filter, for instance one time my camera just decided to get stuck in the up right position. It would not let me move the camera and had to land the drone and turn it on and off. I have the polar pro filters and feel that any wind seems to really push on the filter and affect the camera.
It might be worth your while having a word with Polar Pro, it might be a known issue to them. I have no problems using the DJI filters. I wonder if a gimbal calibration, or adjustment to any of the values would make any difference.
I had same prob. I posted my solution. I chew some gum.....match gum weight with filter weight. stick gum on back of camera and done. no more shaking
I use gum because I worry about interference from a stick on lead weight.
works fine
I made my own filter from a lens shade and an old pair of sunglasses. (polarized of Corse) works gr8
I will prob get set of DJI filters because of weight difference of DJI products match gamble motors specs.
I have the polar pro uv filter and my gimbal is fine. It is bigger then stock uv and pretty sure they are all same size except polarpro uv/cpl filter (little wider) try stock filter see if camera still acts weird
$gambino$ Posted at 2017-1-30 06:52
I am using the polar pro filters and have no Gimbal problems
i believe at one time dji and polar pro said to do a gimbal calibration due to the larger size of the filters. i did one on mine and have never had a gimbal problem with pp filters.
Grizz 1 Posted at 2017-1-30 16:49
I had originally bought the set of 4 polar pro filters that were in the cheaper price range, can't remember exactly how much somewhere between $40 and $50. When I used them I too would get crazy camera movements. So I returned them to best buy where i got them and ordered the polar pro cinema series for $90 and they work so much better.
