FlashGJ
Flight distance : 293379 ft
In my testing on the latest firmware, the MP will loose altitude while tracking you downhill if you are moving fairly slow (walking pace). If you start to pick up speed then all bets are off and it begins to act differently. I have begun testing Autopilot and its Follow mode gives you the option to follow the controller and choose the distance and altitude you want the MP to stay from the controller as it follows. Still learning the program, but it works well. Only two caveats, it is iOS with newer devices that have barometric pressure built in and since it is not following optically, it does not always keep you framed in the picture real well. But unlike Active Track, it will always keep following you and eventually get you back in the frame. Oh, one more thing, you have to be moving faster than about 3 mph for it to work well. |
