Crash
1049 15 2017-1-30
fans4dc5fc21
Flight distance : 1842024 ft
Hello crashed my New Phantom 4 pro into some trees!! Totally my fault, up until then the Pro was a great machine.
My question is after looking at these picture do you think the Drone is worth repairing? The motors still work. It's starts up fine.
If repairable what would I be looking at cost wise?
if not tlrepairable is the bits worth anything ??
Thanks.
2017-1-30
Gil
Flight distance : 1379308 ft
Whew!  How flightworthy it would be after that much damage would be a gamble.  Heck, presuming all the components still worked, Just transferring everything to a new shell would be an effort!  But who knows, if a new body is all it takes to get it into the air it might be worth a shot (but no way is that camera going to work!)
Check ebay to see what used P4 parts are going for.
2017-1-30
Nigel_
Flight distance : 388642 ft
Send it in to DJI for a quote, the P4P parts are still hard to get hold of for DIY and they don't charge too much for new cases anyway.   I guess it will cost less than you expect...
2017-1-30
Connelpilot
Ok will have a look. Thanks for your reply.
Would there be any way the camera could be tested the  lense is still intact.
2017-1-30
RicardoGray
Flight distance : 4356421 ft
Connelpilot Posted at 2017-1-30 09:53
Wow! Yeah it took a shot for sure. Replacing the shell isn't too bad if you are willing to tackle it, and I see your in the UK, but in the US I can buy both halves, landing gear and screws for around $60. Might cost more to send it to DJI, but at least they could test everything to make sure it works properly.
2017-1-30
Connelpilot
Nigel_ Posted at 2017-1-30 09:52
Was thinking about doing that , just need to get a hold of somebody that can guide me through the process.
2017-1-30
Shrek
Flight distance : 61316 ft
Connelpilot Posted at 2017-1-30 10:10
DJI Live chat should be able to assist
2017-1-30
Nigel_
Doesn't look like you can test the camera!
Probably the expensive bit will be replacing the gimbal and it's motors, the gimbal motors seem to get damaged easily as they have to be very lightweight so are not very strong.  The gimbal isn't something you can DIY easily even if you could get P4P parts for it.  It will cost a few 100 including their time, but will certainly be a lot less than a new aircraft.
2017-1-30
Connelpilot
Shrek Posted at 2017-1-30 10:12
Don't want to sound thick but how and where do I get into live chat ?
2017-1-30
Connelpilot
How do I get onto that ?
2017-1-30
Connelpilot
Nigel_ Posted at 2017-1-30 10:22
Sound advise. I woulnt go down the DIY route anayway. Will definitely send it in. Do I need them to send me a shipping sticker ?
2017-1-30
Shrek
Connelpilot Posted at 2017-1-30 10:23
http://www.dji.com/support
Bottom of the page - Online Support
2017-1-30
Connelpilot
Shrek Posted at 2017-1-30 10:44
Thanks shrek
2017-1-30
timbo
Putting on a new shell should be easy enough, you will need to buy a whole new gimbal. You can fix it yourself for around $500.
2017-1-30
Propwash
Flight distance : 13058 ft
Try RC GEEKS their authorised repairers. Based in Crawley.
2017-1-31
KevDrones
Flight distance : 475522 ft
Maybe you could use DJI Care if you have it.
2017-1-31
