Can anyone tell me why my Flight Level is 0 when I tap on the "Me" Icon in DJI GO??? Is it because I haven't uploaded any Artwork and have no Fans or Followers = different scoring than what's on the Data page???
Side-note, I can't believe I have flown almost 28 Miles already!!!
Thanks for the reply RHP...
I always Synch my flights (see clouds at upper right in the in Log Files pictures) and the increasing number of Point/Flights/LV shows my numbers always increase when I Synch my latest flights...
Here's another image form when I posted a while back asking "why do I have 2-screens" (when I only have 1-Drone)...
It doesn't make sense to me that the number of Points,Flights and LV show and increse on logs-page(s) but not on the "Me" page???
I guess no real purpose other than watching the numbers go up = get to see Distance Traveled rather than have to add all the flights up myself...lol...
There are two the same screens because on is overall, second is for this aircraft only. App is designed for more than one drone per account. But still I have no idea why my top altitude is below sea level. I did all flights starting from a place about 120 m above sea level. Highest altitude was about 150m above ground...
Rosomak Posted at 2017-1-31 10:05
DJI often gets locations wrong. Perhaps they think you are flying underground, in a cave...
I have a question, maybe I'm just stupid, but I just synced my flights and it only shows like 19 total. There should be more than 100. How do I retrieve those other flights so they can be synced as well. I have been saving all of my logs to healthydrones. I didn't know how this one worked until now.
When ever you turn on the drone, to make adjustment, there is a flight recorded.
Same if you utilize the onboard flight SIM. I go through my records and delete any that weren't in the air...
Is there any way I can sync my records from day 1 if I deleted them from the P4? I have them all saved to healthydrones, but I didn't know Go had this feature before I deleted logs. So, is there a way I could download them from healthy drones and then sync them to the go app? I really appreciate the help.
C. Dave Pappas Posted at 2017-2-1 04:21
Check your Synch Setting (tap on the gear that I circled)...
It has 3 options for how far back it synchs...
By default it's "All" but maybe you changed that at some point in the past???
Hope that helps
