Flying over Water
1791 13 2017-1-31
KevDrones
Flight distance : 475522 ft
Hello,
I was wondering if the Phamtom 3 Standard can fly over water safely? What are some tips, that someone could do with the phamtom to fly over water? There is no VPS(Vison Pisisoning System) so it wont get confused at the height of water.
2017-1-31
RedHotPoker
Flight distance : 165105 ft
Fly high, and stay dry. ;-)
Some guys feel a floatation device is necessary, while others just take their chances, and hope for the very best.
RedHotPoker
2017-1-31
KevDrones
Okay, and should I set the RTH at like 50% if and fly at 400 ft?
2017-1-31
Geebax
KevDrones Posted at 2017-1-31 17:38
What do you mean by 50% ?
2017-1-31
RedHotPoker
Geebax Posted at 2017-1-31 17:58
When the battery reaches 50% you should begin flying back, Yes...
Providing the wind is at its back... Haha
RedHotPoker
2017-1-31
KevDrones
I mean 50% battery.
2017-1-31
KevDrones
I will probably start off at the shore line after I get used to it on land.
2017-1-31
Labroides
Flight distance : 9991457 ft
Does a plane fly over water safely?  A helicopter etc etc ?
Flying machines fly regardless of what's down below.
Fly over water just like you fly over solid ground.
Over water is good for flying because there's generally nothing to hit and if it's a large body of water like the sea, you'll have a good interference area to fly.
2017-1-31
Cabansail
Flight distance : 136686 ft
I plan to fly from a boat soon. Doing that there will need to turn RTH off and set to Hover. Getting that wrong could result in a controlled descent into water.
2017-1-31
RedHotPoker
Cabansail Posted at 2017-1-31 21:09
If you have a device like the iPad Air2 Cellular, which has a GPS module, you can occasionally change your dynamic home point, to where you are, with the RC...  So no need to worry about it engaging RTH or setting it to a hovering mode...
RedHotPoker
2017-1-31
Cabansail
I am using the iPhone 6S.
Think I will set it to hover if it loses contact and then move the boat back into range and land it that way.
From what I can see the dynamic home point is set from the device at the moment you select it and so from a moving boat it will not be correct. It may be useful to get it back close then manually fly in the final approach.
2017-2-1
KevDrones
So set it to hover and try not go go out of range?
2017-2-1
morganste86
It worked OK for me, this was my first flight over water.
https://youtu.be/-xzcng37RbQ
2017-2-2
DroneSmeg
Flight distance : 478461 ft
Taiwan
morganste86 Posted at 2017-2-2 14:27
Some nice work. Getting that low to the water takes a certain level of bravery.
2017-2-5
