Epic210
Flight distance : 962913 ft
flybabe Posted at 2017-2-5 17:44
ok, we just opened up our 120GB CINESSD and found exactly what was posted as internals above. To open the SSD is really simple. There are 2 T2 tore screws in the front side of it and when unscrewing those you can simply lift up that side panel of the SSD. Takes some slight pull, since the thermal paste inside is holding it together, but really quiet a simple procedure. Then you can just take out the original M.2 SSD blade and swap for a different one. We bought a Samsung 960 EVO 512 GB one and put that inside instead of the original one. Close the housing and plugged it into the DJI card reader. it showed up in our formatting software and we formatted as FAT32 and made it write protected as the original. All worked great and very much straight forward. We then also installed the original 120GB ssd into our M.2 slot on our motherboard and it mounted right away and showed all our clips that were on there. We copied the 100GB worth of date in about 2-4 minutes of the drive (680MB - 1.2GB/s transfer speeds), so as someone suggested above the drives are fast and the only thing crippling it is the USB 3 connector (Really don't understand what the sense behind that USB connection is). So all that was very encouraging and we thought this should be an easy thing, but once we plugged the cinessd into the Inspire 2, it of course did not show up and was a total no go. This means there should be some sort of firmware on the SSD's that shows the Inspire what kind it is and that it is actually a "verified" and "blessed" DJI disk :-)
So unfortunately this will not be an easy swap and go procedure and it might be smarter to just buy the real one's , but lets see what other people might find.
There is an encoding chip on the SSD plug that’s between the actual drive and the end of the plug that goes into the inspire 2.
There are codes and the serial number of the drive in there, I has a accept and deny protocol on it, when the drive is plugged into the inspire the protocol is run and the serial number is compared from the chip to the drive, if you can somehow change the serial number of the actual drive it’s self and match it to the encoder chip then you have your self a bigger drive with more storage. |
