Billy Banana 4
Hello,
I had a bad crash and now the dji go app says the remote controller signal is weak. I also need to to scroll through the different crafts manually instead of it finding the P3 by default. Once I connect, I can turn on the motors and throttle up and down and shut off motors. I have removed the blades so it is not flying. The app also will not set the home point when it connects to the aircraft.
I am also noticing a small green light on the bottomright side that I never noticed before. Any ideas?
IDK if this has anything to do with the crash but now when I try to turn off my battery the power button flashes red for a few seconds before shutting down... This is the same for my spare battery. NOTICE this problem on happens while that batteries are in the aircraft, they shut down fine when not installed on the aircraft
Anyone know if I can download any info from the craft that could help diagnose my issues?
Thank you
