gimbal cable port to gopro
911 5 2015-2-19
myron
Philippines
Hi Dji
i wanna know if the power of gimbal h3-3d to gopro 4 black doesn't effect in the longrun? because gopro required small amount of voltage.
thanks
2015-2-19
tahoejmfc
the h3-3d gimbal does not work with the gopro 4
2015-2-24
freddiebd
Flight distance : 1891184 ft
tahoejmfc Posted at 2015-2-25 01:07
haha. Yes it does!
2015-2-24
tahoejmfc
it might fit right in the gimbal, but the port has been turned 180 degrees by gopro on the back if you have the first version of the gimbal that has the gopro plug in the back. So you are right, it works on the gen 2 version of the h3-3d gimbal with the usb port connection, not the go pro port connection
2015-2-24
myron
Indonesia
because im too much worried the P2 power source up to 11 v but the requirements of gopro4 power supplied is only 5 volts >>>> http://gopro.com/support/articles/recommended-chargers the main concern here GP4 is not a cheap toy but expinsive!
thanks
2015-2-25
DJI-Dboy
H4-3D connects with GP4 via USB port and the voltage is within GP4 spec. Don't worry about that
2015-2-27
