P4 questions
633 7 2017-2-2
WindSoul
Flight distance : 16 ft
1. Can a CW motor be used CCW as well? usually reverse rotation is a matter of wire connection only.
2. can P4 camera be upgraded to P4Pro?
2017-2-2
Nigel_
Flight distance : 388642 ft
1. Usually the screw threads are in opposite directions, but with a P4 motor I guess you can just change the prop mount?
2. I'm certain that will be a no, although I haven't tried.
2017-2-2
Maxi3D
Flight distance : 307621 ft
I would think not as the brushless motor is depending on ESC IC board.
2017-2-2
Jake Phantom 3
Flight distance : 2639747 ft
I believe reversing the motor from CW to CCW and the threads being set up for CC, the propellers wouldn't be self locking, they'd come off on startup, or while your flying.
2017-2-2
WindSoul
Jake Phantom 3  Posted at 2017-2-2 15:29
one supplier only had one type of motor. with the quick coupling i understand that it needs changed as well, but the motor itself i was wondering whether is only a matter of right wire connections. the esc feeds three wires to the motor and those are power, so shouldn't make any difference, i guess.
2017-2-2
Nigel_
WindSoul Posted at 2017-2-2 15:37
It may not even need rewiring since the difference could be in the esc rather than the motor or the connector.
The screws on top of the motors certainly all turn the normal direction so you can just swap the prop holders to the correct direction.
2017-2-2
Grizz 1
Flight distance : 120066 ft
dji uses two different part numbers for the motors, so they must be different
2017-2-2
Odan
Flight distance : 182913 ft
Not a problem with electric heli's....I would imagine that it should be fine in theory.    Just have to have on the correct prop mount...seem to me
2017-2-2
