Dji Inspire 2 X4s Problem Liveview from X4s
1262 6 2017-2-2
Stevie GooGs
Flight distance : 7468868 ft
Today i went to change all my batteries to 1 day as i wont be using the drone for a week or so, i turned everything on and noticed the liveview feed was just static with lines.
Regardless of what i do the x4s feed does not work however the fpv is working fine?
I tried a different location just in case it was interference but no change?
Has there been any updates that would automatically install as i notice both numbers below dont match?
App version 4.0.2
Aircrat version 01.00.0135
Remote Control 01.00.0050
2017-2-2
Stevie GooGs
Here is a sreenshot
2017-2-2
Stevie GooGs
Just found it was an inconsistent update, do things just auto update as I've not manually updated anything?
Problem is now fixed, thanks DJI for giving me a mild heart attack LoL.
2017-2-2
Live Tv
Flight distance : 8104 ft
Hi I have the same issue , the camera has worked a couple of times but mostly as about...   It's not a streaming issue as I recorded the same broken image to the internal SD card. I've reloaded the firmware but with no luck.. what did your do to fix this exact same issue ?
2017-2-3
Live Tv
mine is doing the same thing how did you fix it ?
2017-2-3
steelej80.googl
Hey Guys,
Here's my thread on the issue from a couple of weeks back, very repeatable issue
http://forum.dji.com/forum.php?m ... D385%26typeid%3D385
John
2017-2-4
Live Tv
Thanks.. it seems to be a PAL issue with the camera, cycling to NTSC then back to PAL sorts it out .. hopefully a fix will be in future updates..
2017-2-5
