Go4 app disconnects itself when aircraft had battery warning
1691 13 2017-2-2
ay6810
Flight distance : 76631 ft
Singapore
I had this problem two days ago while on a maiden flight with the Mavic, is that normal?  I still had RC control over the Mavic but despite restarting the GO4 app, it still shows 'Disconnected'.  It was a good thing I was flying LOS so I could bring it back.
The Mavic battery reached 23% when I set the threshold of 24%.
2017-2-2
Milky
I had the same exact issue. On my third flight. Not sure if it was a fluke or what, but hasn't happened since. Not sure if it was the battery or the AC. Since it's happened I've flown three more times and never had the issue again. I'll keep a close eye on this thread and do some research. If I find anything I'll post it here.
2017-2-2
Milky
Also when it happened with me, I didn't press anything and about 8-10 seconds later the phone/app reconnected.
2017-2-2
Hello ay6810, could you please clarify what mobile device you are using? Do you have another mobile device to test with?
2017-2-2
Jenee 2
Flight distance : 7852129 ft
I have had the app shut down on me as well while flying and I had to restart it. It happened a couple of times and wiped most of the log files. I had no warning messages at all and everything had seemed normal.
2017-2-2
ay6810
Singapore
DJI Mindy Posted at 2017-2-2 23:16
Dear Mindy,
I used an ASUS Zenfone 3 Deluxe running on Android 6.01. GO4 was sucessfully installed from Google Play store with no issues.
I have another mobile device but not sure if GO4 will install as its an older ASUS Zenfone 2 Laser.
2017-2-5
Laroba
Flight distance : 99583 ft
Hi
same issue for me, using mavic + samsung s7 + dji go app 4
in my case, mavic turned into RTH and i did not have access to the rc, except for 1 or 2 sec. so i could bring it back to me my way ...
2017-2-6
Angelo26
Flight distance : 799718 ft
Austria
Unfortunately You are not alone with the problems of DJI GO 4 on Android ................
See this thread: DJI GO 4 problems on android
2017-2-6
Adi 53
Israel
Hi there , i try to use my new Mavic Pro (I have Phantom 3 Pro too), and i got the same fenomenal , DJI Go 4 App had many times disconnected issues in short and medium range , and i didn't take the risk to fly it behind my visual range. DJI R&D team musk solve this issue before many users will begin to complain that their DJI drone crashed !!!
2017-2-7
CuaC
Flight distance : 369626 ft
Just had this happening to me, third flight, kinda scary, the aircraft was back with me and it initiated the autolanding and sat down by my side.
2017-2-15
ay6810
Singapore
CuaC Posted at 2017-2-15 04:46
Try changing the DJI cable that connects the RC to your phone/tablet.  I changed that and had no problems after doing so.
2017-2-18
CuaC
ay6810 Posted at 2017-2-18 02:06
On my next flight it complained about battery firmware inconsistency, hit update and no further issue so far.
2017-2-18
ay6810
Singapore
CuaC Posted at 2017-2-18 04:51
That's a new one...never got one of those battery inconsistency messages....
2017-2-19
CuaC
ay6810 Posted at 2017-2-19 03:23
I had updated the firmware the day before the issue. My guess is it didn't update properly the battery and on my next flight for some reason the inconsistency wasn't detected. After that second update the problem has disappeared.
2017-2-19
