CANT GET CAMERA TO YAW IN FLIGHT ( HElP)
1195 7 2017-2-2
fans152da1f9
Flight distance : 142687 ft
I just took my Inspire 2 out for the first flight as soon as landing gear goes up I can not 360 the camera, when landing gear is down no problems.
RD
2017-2-2
Arrow1969
Flight distance : 400577 ft
Set it to free mode second icon down on the left on the Go App, if you then press and hold the C1 button then rotate the left dial wheel, you can adjust the gimal yaw.
Is that what you were look for???
2017-2-2
DJI-Jamie
Flight distance : 112405 ft
Arrow hit the nail on the head.
2017-2-2
fans152da1f9
Arrow1969 Posted at 2017-2-2 20:25
Thank you I will try tonight when I get home, its weird because like I said it works when landing gear is down.
2017-2-3
Arrow1969
fans152da1f9 Posted at 2017-2-3 07:57
Yes it does work on the ground in the air you have to do set it as I described in my previous post.
It fold me the first time I tried in the air after I had tested it on the ground
2017-2-3
KNOTENOUGH
Arrow,
That was it thanks again! Do you shoot in DLOG?
2017-2-3
Arrow1969
KNOTENOUGH Posted at 2017-2-3 15:49
Arrow,
Hi KNOTENOUGH,
No I didn't I normally do only been out 5 time with it the weather over here is terrible at the moment.
2017-2-3
GabeZ
Flight distance : 768448 ft
Based on my experience, the camera doesn't stay centered in free mode. You have to keep resetting  yaw.  There go to be a way to allow yaw with c1 and have it just re-center ifsel
2017-2-4
