Gimbal horizon issue.
794 9 2017-2-3
mpaka
Flight distance : 19252874 ft
Serbia
[size=14.6667px]Below is the video of P4P tested indoor on table which shows just how much my gimbal moves around in 4 positions.
[size=14.6667px]Did cold calibration of IMU, and gimbal calibration right after that. More than one gimbal calibration... Everything stays the same.All this happens during flight too.
[size=14.6667px]Any solution maybe?
[size=14.6667px]C2+wheel and manual roll adjust is not an option.
[size=14.6667px]Had P3P before this and it worked like a charm. Calibrated gimbal once in a year, flew over 900km in 12 or so months.
2017-2-3
BlueMan
Flight distance : 73087 ft
i have the exact same problem. what do i do? send it back?
2017-2-3
QiiFlight
Flight distance : 2999472 ft
Have you tried adjusting the gimbal movement parameters in advanced settings? I believe there is a setting that adjusts the speed at which the gimbal compensates.
2017-2-3
Grizz 1
Flight distance : 120066 ft
it looks normal to me. the gimbal roll adjustments are adjustable in the app.
2017-2-3
Grizz 1
they will have some changes in the next firmware update that will address the gimbal issues you might have. no need to send the aircraft back.
2017-2-3
mpaka
Serbia
Grizz 1 Posted at 2017-2-3 06:28
It is not normal, trust me
I hope this is something that can be fixed within next FW update.
And i would like to hear someone from DJI Staff say something about gimbal problem fix in next FW, and when can we expect it. Thanks!
2017-2-3
L N
Estonia
I have chnged 3 P4P, and now I have 4th. wirsth have problem with recording 4k 60fps. and other 3 have exact same problem + gimbal balanc problem, which causes vibration.
2th one
3th one
2017-2-3
mpaka
Serbia
Here it is doing the same thing during flight.
2017-2-3
blackcrusader
Flight distance : 689774 ft
Taiwan
Wow. Clear to understand your issue.  I bought a P3S and have none of that.
I know there are software changes you can make but your Gimble looks like it is not even trying to level out.
2017-2-3
mpaka
Serbia
blackcrusader Posted at 2017-2-3 15:54
Had P3P before this, and gimbal was rock solid.
It is trying to level, actually it is over-compensating. Instead of keeping gimbal level at horizon, it rolls gimbal to the oposite side of drones bank.
2017-2-4
