Dronoob
Flight distance : 126079 ft
I just downloaded the original file.
- The video frames are very sharp.
- The stuttering is as I would expect at that rotation speed at sun light for 4k/30fps.
- There is no jello effect at the end in the original video but there is a slight movement which can cause jello when the video is sized down to 1080 or other resolutions using bad interpolation algorithms.
Summarizing: The video looks OK to me. To improve the smootheness of your video, you should consider buying ND filters to get the shutter speed down to 1/50 so that the single video frames get longer exposed and thus capture more motion blur.
Back to the issue: As the original video looks much better than the result in the online playback, I think there is a video transcoding issue outside the Mavic. If you are seeing the same issue on your device, please check the video transmission settings. Sorry, I can only give you some hints where to look into this issue. I have no solution for this but I am quite confident, that the Mavic's camera is OK. Hope that helps.
