Mavic from US in Europe
2608 7 2017-2-3
NugGerath
Flight distance : 135118 ft
Poland
I want to buy Mavic from US and use it in Europe - are there some major differences between US and EU versions of Mavics - or what I need is just some kind of AC POWER cable adaptor (US/EU)?
I suppose FCC and CE range is self adaptable based on GPS location - right?
2017-2-3
Flybee
Flight distance : 2203983 ft
So why should you want to by a US version then? it is sele adaptable based on GPS location.
2017-2-3
NugGerath
Poland
Flybee Posted at 2017-2-3 10:19
Because it is available right now, no need to wait for delivery from DJI
2017-2-3
Flybee
NugGerath Posted at 2017-2-3 10:33
I think it's the same you don't have to worry about that. On my box it said EU version, and the only thing that differs is the cord. Are you buying from a local store or what?
2017-2-3
Zamboon
Flight distance : 1332844 ft
Zambia
Yes, huge difference in price if you can get it shipped to a US address. No differences at all otherwise save the plug which you can sort out with an adapter.
2017-2-3
NugGerath
Poland
Flybee Posted at 2017-2-3 11:12
One of the local shop got few Mavics from US.
2017-2-3
Flybee
NugGerath Posted at 2017-2-3 11:59
Aha but then go ahead if you want it now, just get the plug and then you are set to go, wonder how they will threat the Warranty though but you should ask the dealer it would be taught to go to US to have it sent in.
Good luck to you.
2017-2-3
4wd
Flight distance : 545817 ft
US voltage is 110V but the charger is the same it will automatically cope with either.
The lead is a common enough type which plugs into the charger.
You will probably be able to find a suitable one with local plug fitted - safer than adapter but check the fuse 2 amps probably because charger is only 50w
2017-2-3
