No image in Vision app
123
37431 85 2015-2-19
Madskvik
Denmark
Well.. I have the same problem and have no idea what to do. I need help aswell
2017-3-27
TomWolves
Flight distance : 110577 ft
Gareth, do you have telementry on your screen, but no video?, if so you probably need a WIFI module.
2017-3-30
fansedf0b0a4
Flight distance : 2156 ft
homer@paddocks. Posted at 2015-2-19 16:55
I received my unit Jan 22 2015
I Sent the following to DJI 02/13/2015
This may or may not work for you but what I did was take the memory card out and put back in three times to make sure all contacts were making good contact and that fixed my problem. Good luck.
2017-6-9
prebengori
Denmark
Gareth:
Had same problem.
I pressed the small wires and plugs on the top plate of the camera firmly im place and everything worked again.
good luck.
Best regards, Preben
2017-8-11
prebengori
Denmark
Madskvik Posted at 2017-3-27 01:13
Gareth: (and others)
Had same problem.
good luck.
2017-8-11
Paky50
Hi, i have the same problem. I change the wifi extender but nothing. All function work but i dont see the image on the smartphone.
Please, help me.
2017-10-19
123
