Purple banding
fans0b8e330e
Flight distance : 197060 ft
Hey
I have Mavic. It is a truly ingenious device! There is a small issue with the camera when I turn it downward.
Purple interference interrupts the footage, leaving it useless and unusable in places. The interferance is frequent and consistent.
The unit itself has not been damaged, in fact, it has only been used four times.
I have updated the firmware to the latest edition
I have calibrated the gimbal
I have watched countless videos on which settings are the most appropriate
Nothing seems to remove the issue.
The interference does not occur when the camera is in the forward position.
There would also appear to be some other noise in the shot:
I have contacted DJI, raising the same issues, but thought that it would be a good idea to share my woes and see if the community at large can help.
I really appreciate your assistance.
Cheers
Pat
2017-2-4
Ex Machina
Flight distance : 1806362 ft
Bummer. My guess would be a bad ribbon cable to the camera. Hope you get it sorted soon and let us know how it gets resolved.
2017-2-4
dronist
Does the purple shows up on the screen while filming?
Does it show when you paly from SD Card?
Does it show when you copy the movie to the computer and play it directly from the computer?
2017-2-4
Pat McMahon
dronist Posted at 2017-2-4 18:26
Hey!
It shows in real time on the iPhone as soon as the camera is switched.
2017-2-4
Pat McMahon
It's also there in post, just the same as it was when it was filmed.
2017-2-4
Pat McMahon
Ex Machina Posted at 2017-2-4 16:01
Thanks. Yeah, I thought as much. It's a consistent fault.
2017-2-4
Jenee 2
Flight distance : 7852129 ft
Pat McMahon Posted at 2017-2-4 20:32
Perhaps as a last resort, perform an IMU calibration as this seems to have fixed a number of camera issues, then do the gimbal calibration after.
2017-2-4
Pat McMahon
Jenee 2 Posted at 2017-2-4 20:48
OK, Cool. I'll give that a shot and keep you updated.
Thanks!
2017-2-4
Pat McMahon
I'm open to any other advice in the meantime or similar incidents.
2017-2-5
Pat McMahon
I'm open to any other advice in the meantime or similar incidents. Thanks
2017-2-5
