BenStein
Flight distance : 2066532 ft
piowoc73 Posted at 2017-2-6 10:54
Thank you for the clarification!
So, are you saying that you had a very good signal 4900 ft from your base on 5.8Ghz frequency? That's really far, so I would assume using 2.4 GHz at all would be more risky than just switching to 5.8 GHz for good.
I was thinking about that last night when somebody started using his drone 20 ft from me while he saw that I was at the spot first, so I waited until he runs out of battery to take off. He had one of the older DJI models, so I thought about switching to 5.8, because this was we could avoid any interference.
Yes, on a recent flight I topped just a bit above 4900 feet distance in line of sight from home using 5.8 GHz and the HD video signal was still clear, although if I turned the remote at all away from the recommended orientation (90 degrees antennae to aircraft) described on pg 40 of the 1.2 version of the manual (under "Optimal Transmission Range"), it would warn of "weak image transmission". So as long as I kept the remote properly pointed at the aircraft, all was well.
In general, 2.4 GHz is considerably more crowded ISM band currently (thankfully leaving 5.8 more open for our use, at least for the time being). But out in the boonies, there is still likely to be pretty clear airwaves on either frequency. I do usually stick to 5.8 just to avoid potential interference and since have not encountered any problems with range, I have had no reason to use 2.4 at present. |
