freelanderuk
Flight distance : 177720 ft
fans3d7e60a1 Posted at 2017-2-10 18:10
For the second time in a row after more than 100 flights, in mid flight my gimble suddenly goes limp and then tries to correct scaring the hell out of me looking like it's struggling to stay airborne but I can see it's flying fine, I immediately land and can see the camera not pointing ahead as it should, both times I've powered it down and restarted it and the gimble goes back to its correct positioning, and both times I've made sure I'm on level ground and performed a gimble calibration, I don't understand why this is happening, is this something that requires it going back to DJI in a California? This is not my original drone, the one I bought from Apple had severe range problems and the rubber feet in the landing gear were falling off, so I sent it back to DJI and they sent me a refurbished one, ( I could tell because the rubber landing gear skids were dirty and scuffed)
Is this refurbished one beginning to fail?
When you say you make sure are on level ground to do the gimbal calibration, try doing on at home on a surface that is level , I have a work top that I checked with a spirit level to do mu IMU and gimble calibrations on and never had a problem , this my help you or may not but it's worth trying |
