Phantom 4 Pro Gimbal Shaking
3705 12 2017-2-5
TravisSRT
Flight distance : 68555177 ft
Just started shaking yesterday for no reason.  Now it even shakes when sitting on the ground with motors off.  Here's an example video.  This isn't the worst of the shaking but gives you an idea what it's doing.  Makes video unuseable...  Any ideas?  Tried calibrating everything, IMU, Compass and Gimbal.  Running latest firmware and latest GO app on a 9" iPad pro..  No crashes ever and it stays in a hard case with factory gimbal lock installed when not in use.
2017-2-5
DJI Natalia
Flight distance : 318 ft
May I know how long you've owned it?
It never hard landing, right?
How about the firmware version? please check and make sure propellers and vibration absorber are fine.
Would you please upload an original video from SD card to dropbox? please do not edit it at all, thanks.
2017-2-6
TravisSRT
DJI Natalia Posted at 2017-2-6 02:09
Hey Natalia, I bought brand new on December 8th 2016. No hard landings, hand caught by landing legs most of time to prevent tip over.  Firmware and GO app on latest versions.  Switched to brand new set of props with same issue.  Also shakes on ground.  I just sent back to DJI for diagnosis/repair/replacement and can send you the Case number if you like. My fear is that I will get a refurbished replacement now after reading other posts....
2017-2-11
TravisSRT
https://www.dropbox.com/sh/jguv7 ... fAqERJjGUobxka?dl=0
2017-2-11
DJI Natalia
TravisSRT Posted at 2017-2-11 10:54
Since you've sent it in, our engineers will take care of it once it's delivered.
It's nice you can give me your case number.
2017-2-12
TravisSRT
DJI Natalia Posted at 2017-2-12 01:33
I just messaged the case number to you
2017-2-13
DJI Natalia
TravisSRT Posted at 2017-2-13 04:09
OK, got it, thanks.
2017-2-14
墨老爷子
DJI R&D Squad
T_T .... please send it back, that's  odd...
2017-2-23
Flyboy4969
I'm having the same problem. No hard landings ever & relatively low time usage. How do I go about getting this remedied?
2017-9-25
Goran_m_pg
Flight distance : 616070 ft
Montenegro
What was the problem with this one? Was it vibration absorbers since they get damaged from gimbal protectors from what i heard?
2018-1-26
kykphantom
Flight distance : 5892388 ft
Cyprus
Any news about how this problem is fixed?
2018-2-4
kykphantom
Cyprus
Is the issue solved?
2018-2-4
kykphantom
Cyprus
Goran_m_pg Posted at 2018-1-26 12:17
Dear Goran, did you get any answer on this issue?
2018-3-13
