Jello effect?
1669 12 2017-2-6
Disane
Flight distance : 56240 ft
Is this the allmighty Jello effect everyone is aware of?
Already calibrated IMU, Compass and Gimbal. Filmed in 4k and 1080p.
tested other sd-cards like the bundled lexar and SanDisk Exteme.
Should I return it to DJI?
By the way. this was one of the first flights with the Mavic. Everything is new.
2017-2-6
Wandering Cloud
Flight distance : 839633 ft
My new replacement Mavic suffers the same problem and I think it is because of the wobbly hind leg. The vibration from the motor seems to affect the gimbal much more when the leg is loose.
I try to prove my theory by putting a rubber peg in between the joints to stop the hind leg from moving / vibrating while flying, and lo and behold, the jelly / shaky effect is now gone.
But there are so many possible causes, such as gimbal obstructed by something or not fit properly etc..
2017-2-6
Disane
so a RMA should be considered in your opponion?
2017-2-6
fans48d34f9f
Flight distance : 199554 ft
After my 3rd flight I got the Jello. Didn't have it on first flights. Just reading up on it now seeing how to hopefully correct it. Never had it on my phantoms
2017-2-6
Disane
can you provide me your solution if it works?
2017-2-6
SrMi
Flight distance : 3425 ft
What do you mean 4K and 1080p? I do not see any change in resolution. I believe 1080p should be avoided. What shutter-speed did you use?
2017-2-6
Could you please upload the original video files to dropbox and send me the link?
I'll help to check it.
2017-2-6
Disane
@DJI MIndy: It's currently uploading.
https://www.dropbox.com/sh/xxjt2 ... QCAEHVMuAbIK8a?dl=0
The mentioned clip is DJI_0054.MOV. In addition, I attached some other clips which are affected by the error.
Edit:
I've flown on different temperatures. The problem persists with 0°C and around 10°C
2017-2-7
Disane
Could you open the filets?
2017-2-8
harfordhawk
Flight distance : 18668 ft
I have the same problem sometimes worse sometimes hardly noticeable.  I was wondering if it was just "the way it is" and I was asking too much?  Anyway, I will be interested to see if there is a problem that DJI Mindy can resolve .
2017-2-8
WYHSniper1007
Flight distance : 1003822 ft
You should contect with DJI
2017-2-8
Philby
Having major "jello" issues with my new Phantom 4 PRO.  Only been used 6 times... have tried re-calibrating everything and a re-boot  :-(
Any solutions?
2017-2-12
Disane
I just tested another Shutter-Settings but this wont work. Additionally I got a sprinkle on my lense, which I actually discovered last week. Just return it to DJI.
2017-2-13
