DroneFlying
Flight distance : 10774613 ft
When people mention uploading the flight log, they're talking about a file that's created / stored on your mobile device during the flight. Here's a link to the Healthy Drones instructions on how to do that.
From the screen shot you provided, it looks like the Mavic's last reported position was at the edge of some trees; what is / was your RTH altitude set to? Most likely it wasn't high enough for your Mavic to clear the tree line. And as far as the path right before that not being straight goes, that was probably object avoidance (OA) being activated to prevent it from running into obstacles (trees). Yes, the automated RTH will try to return to you in a straight line, but if OA is active it'll also try not to run into things on its way back and can / will deviate from the straight line if it needs to. On the other hand, if it reaches a line of trees that's taller than its RTH altitude, it'll never make it back to you because it won't ascend higher than you've allowed it to. |
