DJI-Jamie
Flight distance : 112405 ft
Jetpilot Posted at 2017-2-8 15:30
I orient the antennas exactly as outlined in the video. I have ever experimented with changing the orientation to see if anything matters with no change. It doesn't matter if I am 10 feet or 300 feet from aircraft, still same issues.
Try the following to see if it helps:
Try to reset the RC:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the aircraft and the controller and link the remote.
After that, I would recommend relinking the RC to the aircraft using the following:
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button on the controller, then the controller will beep like D-DD.
*Let go all fingers, press the wheel on the right side of the controller and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon.
