What does this beeping mean?
3883 13 2017-2-12
Noyag
Flight distance : 857946 ft
Does anybody know what this beeping means? It comes from the transmitter and nothing shows up on the DJI Go app. It is at 1:14 in this video:
2017-2-12
RedHotPoker
Flight distance : 165105 ft
Sounds normal to me..
RedHotPoker
2017-2-12
Nigel_
Flight distance : 388642 ft
It was telling you that there was another aircraft in the air 9.5 meters away and to be careful - look at the radar display, one of the green bars illuminates and "9.5M" appears...
2017-2-12
Phantom Robin
Flight distance : 128839 ft
Belgium
English :
That's normal, because you where pointing your sensors to the sun, it was obstacle avoidance. Btw, my personal suggestion, never use return to home when you are that close, it will auto land that's normal, fly home on the map, use it only incase something is really wrong as a last resort.
Dutch :
Ik heb dat altijd als ik mijn sensoren in de zon laat kijken
2017-2-12
WindSoul
Flight distance : 16 ft
this is a wild guess: maybe the other drone was also a P4 and the VPS is infrared, then your drone has detected the ir from the other and interpreted as a reflection of own ir and decided there's an obstacle ahead.
2017-2-13
KM5RG-Robert
Flight distance : 2075213 ft
Obstacle avoidance shown on the screen of the app. Obstacle at 9.5 meters. Pretty clear (and pretty impressive).
2017-2-13
Aardvark
Flight distance : 384432 ft
Certainly caused by the Obstacle Avoidance, I believe some can be erratic when facing towards the Sun (internal reflections seen as Objects). A calibration of the sensors using DJI Assistant 2 might help resolve that  'Phantom' Object.
2017-2-13
Odan
Flight distance : 182913 ft
They are right...OA sys. work way cool on Phantoms.   On mine even the smallest of twigs will stop it.
wigged me out the first time it happened to me.  I'm still learning how to operate this Phantom 4.  It has been working way beyond my wildest dreams.
Even now when it happens,  I get all panicky and think i's getting ready to fly off or something like that. ( reading some of the problems that occur on this forum keep me on edge)
Learn to love that sound....It means your head is up your ??? and your drone is flying itself.  What could be better ??
2017-2-14
Mobilcams
Flight distance : 2907674 ft
Isn't that noise made by the controller too when it's firmware is being updated?
2017-3-17
Steelinox
Flight distance : 168891 ft
I have had a few "rapid beep" starts that continue past initial boot up and do not stop. I power the controller down and reboot; a few times to clear the anomolous boot up.
2017-4-2
Noyag
Steelinox Posted at 2017-4-2 14:44
Thanks for your suggestion. I now know this was the obstacle avoidance system. But the weird thing was that it did not display anything in the app. My drone has been replaced by DJI.
2017-4-3
Steelinox
Noyag Posted at 2017-4-3 23:24
come to find out that the beeping is actually a "controller (joy stick) calibration" warning. I did the calibrate and problem solved. Thanks to fb group DJI PHANTOM 4 & 4 PRO
2017-4-5
DJI-Jamie
DJI Team
Flight distance : 112405 ft
Steelinox Posted at 2017-4-5 17:15
Good to hear you got it sorted.
2017-4-5
paukstis91
Lithuania
last day I had that beeping also. No notification, no errors, just beeping flying toward east. And I did not understood what is it. After my flight was done, I saw another one guy with some kind of drone flying around in the same field where my drone was, but at that moment i didnt realized it! Now I understand
2017-4-5
