Litchi App for standard
2080 11 2017-2-12
Bay Cruiser
Flight distance : 2039288 ft
Is Litchi better than DJI go for iPhone 6s and phantom 3 standard. I hear a lot of praise for it so please let me know the good and the bad re this app.
I am fed up of wifi inference error messages and having to continually adjust my aerial for RC weak signal at only 100 metres away. Will Litchi cure this or is it just the standard as I have to keep moving my aerial that goes from 0 to 5 bars with a very very small movement of the aerial ?
2017-2-12
Geebax
Well, it does not cost much to find out.
2017-2-13
Bay Cruiser
More interested in if it RTH properly as I have heard it may not in certain circumstances. That worries me more than anything else. So will see if anyone replies.
2017-2-13
Rene Jensen
Denmark
everything is working 100% in litchi and its worth every penny
2017-2-13
blackcrusader
Flight distance : 689774 ft
Taiwan
Bay Cruiser Posted at 2017-2-13 00:33
RTH was already fixed and the new 3.1.3 app works fine. I have flown and used the RTH no issues.
I installed an Argtek antenna on my P3S and it works great.  1.83km on first long flight and RTH fine.
I also fly in areas that have high terrestrial interference and the Argtek helps a lot as it has a much stronger setup.
2017-2-13
blackcrusader
Taiwan
Rene Jensen Posted at 2017-2-13 01:15
Yup I may want to use it as I can fly long way point missions which I cannot do atm.
2017-2-13
Bay Cruiser
Thanks good to know
2017-2-13
Bay Cruiser
blackcrusader Posted at 2017-2-13 01:52
So I assume this is relating to the go app not litchi
2017-2-13
blackcrusader
Taiwan
Bay Cruiser Posted at 2017-2-13 12:25
Yes it is from the Go App 3.1.3
2017-2-14
#shotxclvck
Flight distance : 3423297 ft
#goodluckwiththat
2017-2-14
Phantom-Paul 7
Flight distance : 2551634 ft
Litchi is not going to magically cure your signal problems , that is just the way the P3 Standard is corners had to be cut to keep the costs down and one of those corners was the telemetry link. The P3 standard is a great bird for the price you just have to work around its limitations.
Litchi will add to the Phantom experiance and in some cases perform better than the Go App but it wont turn your P3 Standard into a a P3 Pro. For the price it is well worth trying if you find you dont like it you only have to give up coffee or cigarettes for a week to pay for it.
2017-2-14
Bay Cruiser
Phantom-Paul 7 Posted at 2017-2-14 18:33
Great that is very useful info, so it doesn't cure the silly wifi interference message that dji go have set too low. I might try it but just didn't want to lose my drone because of a RTH issue I read about with Litchi and the Standards.
2017-2-14
