how to turn off vps?
3756 2 2017-2-13
freddyms
i was trying to hover about 5 ft over water for some pictures and im sure that was the problem. mavic was going up and down left and right. I was looking through options and could not find it.
2017-2-13
DroneFlying
Flight distance : 10774613 ft
I don't have my system with me at the moment, but I seem to recall that it's under Advanced Options on the Sensors menu -- though that may very well be incorrect. In any case, I've hovered closer than 5 feet to the surface of water with VPS enabled and didn't see the behavior you described, so I doubt that was the reason for what you experienced. If anything, VPS should tend to make your flight more stable, not less.
2017-2-13
freddyms
DroneFlying Posted at 2017-2-13 07:51
yeah it is. you know the theory, once you ask a question, you figure it out in a minute. I just needed to tap advance setting under sensors tab. now to try it 4 feet over water and see how it acts
2017-2-13
