Traveling with Phantom -- Plastic gimbal guard question
2394 13 2017-2-13
sdevan45
Flight distance : 6493 ft
Does any put the plastic gimbal guard back on for travel.  It was kind of a pain to get off and I imagine it's equally painful to put back on.  As fragile as the gimbal mechanism is, I don't know which is the greater risk--traveling with it off or on.
Thanks.
2017-2-13
Mark The Droner
Flight distance : 2917 ft
The more you do it, the easier it gets.  I would put it on for travel.
2017-2-13
RedHotPoker
Flight distance : 165105 ft
Yes, put it on. Which guard do you have?
Post a pic of it...
RedHotPoker
2017-2-13
sdevan45
RedHotPoker Posted at 2017-2-13 10:58
Here is the guard I have
2017-2-13
RedHotPoker
Ok, that one. & so you have trouble removing and replacing it?
Let me post a decent video, demonstrating the best way to apply this gimbal guard.
Hang on a moment, while I retrieve it for you...
Ok, here you go..
And another pilots method.
RedHotPoker
2017-2-13
WilliamM
Flight distance : 904364 ft
You have two options, sand this one down where it feels tight or you can buy a aftermarket one, there's a few to chose from.
Here's the one I use. https://www.amazon.com/gp/produc ... 8_s00?ie=UTF8&psc=1
2017-2-13
RedHotPoker
WilliamM Posted at 2017-2-13 11:31
You have two options, you can sand this one down where it feels tight or you can buy a aftermarket one, there's a few to chose from.
Here's the one I use. https://www.amazon.com/gp/product/B015SLYAO2/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
No sanding needed, just learn to apply it correctly.
Besides, you want it to remain snug fitting. ;-)
Sure you may "choose" a different design, but meanwhile the OEM DJI guard works fine.
RedHotPoker
2017-2-13
Pugsley
I use one of these, has the advantage of both holding the gimbal steady and covering the lens.. and a lot easier to take on and off.
2017-2-13
sdevan45
Got it,
The second video was great.  I played with it and have it figured out now.  It is snug, but once you get the alignment correct, it works just fine.  Thanks for all the help.
2017-2-13
WilliamM
Pugsley Posted at 2017-2-13 11:55
I use one of these, has the advantage of both holding the gimbal steady and covering the lens.. and a lot easier to take on and off. [view_image]
+1 on that, mine as seen above is similar to yours. Like it much better than stock, and as you say have double function.
2017-2-13
RedHotPoker
sdevan45@cox.ne Posted at 2017-2-13 11:57
Got it,
Ok, bro, that's very good news. Glad it has helped you replacing it.
I know many of us struggled with that thing in the beginning.
But once you have the knack, it goes on quite easy. Enjoy... ;-)
When I first got my Phantom 3 Pro, my guard was at the bottom of the shipping box...
Perhaps they had the exact same difficulty you experienced. Haha
RedHotPoker
2017-2-13
RedHotPoker
Yup, same here, but it is tight around the camera.
Thanks to my forum friend @Rigworker, for giving it to me...
RedHotPoker
2017-2-13
Brayan2134
Flight distance : 138205 ft
I have one of those gimbel camera holder things I got. It's faster to put on than the plastic thing, and has more protection against little bumps here and there.
2017-3-3
Maxxgold
Flight distance : 19157 ft
I use the one that came with my P4 Pro, and I also use the foam insert on the neck. I also have a long purple piece of fabric attached to the gimbal guard so that I don't forget to remove the gimbal guard.
2017-3-3
