RSW
Flight distance : 116736 ft
piowoc73 Posted at 2017-2-14 10:58
The point of having it indicated in degrees is that you can pre-program it later in a waypoint mission, e.g. in Litchi, or any other apps. I would like to be able to control what the camera sees at each waypoint without actually going there first (not as in draw mode of DJI app), so I need to know which gimbal angle should I set. For that I would just need to go up to exactly the same altitude (corrected of any differences in terrain height at the waypoints), set up the gimbal pitch, which works best for my composition, read the degrees and put it in Litchi app. Hope this makes sense.
Without that being possible you might just launch Litchi and take a series of photos with 10 - 15 degrees between each one to get an idea of the angle you envision. After a while you just get a feel for it. I agree that the visual indicator of the gimbal angle in the app is not of much value. |
