Front Obstacle detection does not respond
1111 8 2017-2-15
Luu
Flight distance : 153990 ft
Switzerland
Hello, I'm new here (:
I got my drone this monday but I think I have a "little" issues.. if I click on a flight mode, I got this message:
Dji phantom 4 pro front Obstacle detection does not respond
Can someone help me?
2017-2-15
Nigelbrinkmann
Flight distance : 586391 ft
Hi, you will have to check to see if the OA is turned on in the app.
Have you been through the app and set everything up?
2017-2-15
Luu
Switzerland
Nigelbrinkmann Posted at 2017-2-15 01:09
Yes, everything is up... the Obstacle Avoidance setting is enabled, The front Radar works in normal mode.. but the Visual Navigation icon is always red and it says it's to dark.. (I tested it at a sunny day...) and if I want to use as example the active track it gives me the error...
2017-2-15
Cetacean
Flight distance : 2528264 ft
Luu Posted at 2017-2-15 01:15
Aloha Luu,
     Have you removed all the lens covers?  Sometimes shipping covers are used for protection.
Aloha and Drone On!
2017-2-15
Luu
Switzerland
Cetacean Posted at 2017-2-15 02:57
Aloha Luu,
Aloha back Cetacean!
Yes I removed all lens covers and stickers...
2017-2-15
Cetacean
Luu Posted at 2017-2-15 03:05
Aloha Luu,
     The next thing will be to calibrate the sensing system.  The Obstacle Avoidance is based on the sensing system.  You will have to use the Assistant 2 and a laptop or computer display to calibrate the sensing system.  If there is a hardware failure in your sensing system, this will reveal it.  If there is no hardware problem, this will fix it.  Good Luck!
Aloha and Drone On!
2017-2-15
Luu
Switzerland
Cetacean Posted at 2017-2-15 03:40
Aloha Luu,
I'll test it this eve!
Thanks!
2017-2-15
Luu
Switzerland
Aloha Luu,
Soulution
I calibrate the sensing system and refresh the firmware with the dji assistant 2 and it works now!
Thanks to everyone who helped!
2017-2-20
Cetacean
Luu Posted at 2017-2-20 02:23
Soulution
Aloha Luu,
     Great to hear that!
Aloha and Drone On!
2017-2-20
